Re-create VLANs, interface groups, and broadcast domains on node3
Contributors netapp-pcarriga Download PDF of this page
After you confirm that node3 is in quorum and can communicate with node2, you must re-create node1’s VLANs, interface groups, and broadcast domains on node3. You must also add the node3 ports to the newly re-created broadcast domains.
About this task
For more information on creating and re-creating VLANs, interface groups, and broadcast domains, go to References and link to the ONTAP 9 Network Management Guide.
Steps
  1. Re-create the VLANs on node3 using the node1 information recorded in the Relocate non-root aggregates and NAS data LIFs owned by node1 to node2 section:
    network port vlan create -node <node_name> -vlan <vlan-names>
  2. Re-create the interface groups on node3 using the node1 information recorded in the Relocate non-root aggregates and NAS data LIFs owned by node1 to node2 section:
    network port ifgrp create -node <node_name> -ifgrp <port_ifgrp_names>-distr-func
  3. Re-create the broadcast domains on node3 using the node1 information recorded in the Relocate non-root aggregates and NAS data LIFs owned by node1 to node2 section:
    network port broadcast-domain create -ipspace Default -broadcast-domain <broadcast_domain_names> -mtu <mtu_size> -ports <node_name:port_name,node_name:port_name>
  4. Add the node3 ports to the newly re-created broadcast domains:
    network port broadcast-domain add-ports -broadcast-domain <broadcast_domain_names> -ports <node_name:port_name,node_name:port_name>
