Relocate failed or vetoed aggregates
Contributors netapp-pcarriga Download PDF of this page
If any aggregates fail to relocate or are vetoed, you must take manually relocate the aggregates, or override either the vetoes or destination checks, if necessary.
About this task
The relocation operation will have paused due to the error.
Steps
  1. Check the EMS logs to determine why the aggregate failed to relocate or was vetoed.
  2. Relocate any failed or vetoed aggregates:
    storage aggregate relocation start -node <node1> -destination <node2> aggregate-list * -ndocontroller-upgrade true
  3. When prompted, enter y.
  4. You can force relocation by using one of the following methods:
    Option Description
    Overriding veto checks
    Enter the following:
    storage aggregate relocation start -override-vetoes * -ndocontroller-upgrade true
    Overriding destination checks
    storage aggregate relocation start -overridedestination-checks * -ndo-controllerupgrade true
