Retire node1
Contributors netapp-pcarriga netapp-thomi Download PDF of this page
To retire node1, you resume the automated operation to disable the HA pair with node2 and shut node1 down properly. You must later remove node1 from the rack or chassis.
Steps
  1. Resume the operation:
    system controller replace resume
  2. Verify that node1 has been halted:
    system controller replace show-details
After you finish
You can decommission node1 after the upgrade is completed. See Decommission the old system.
