Ensure that the new controllers are set up correctly
Contributors netapp-pcarriga netapp-thomi Download PDF of this page
To ensure correct setup, you must enable the HA pair. You must also verify that node3 and node4 can access each other’s storage and that neither owns data LIFs belonging to other nodes on the cluster. In addition, you must ensure that node3 owns node1’s aggregates and that node4 owns node2’s aggregates, and that the volumes for both nodes are online.
Steps
  1. Enable storage failover by entering the following command on one of the nodes:
    storage failover modify -enabled true -node <node3>
  2. Verify that storage failover is enabled:
    storage failover show
    The following example shows the output of the command when storage failover is enabled:
    cluster::> storage failover show
                                  Takeover
    Node           Partner        Possible State Description
    node3          node4          true     Connected to node4
    node4          node3          true     Connected to node3
  3. Take one of the following actions:
    If the cluster is a…​ Description
    Two-node cluster
    Enable cluster high availability by entering the following command on either node:
    cluster ha modify -configured true
    Cluster with more than two nodes
    Go to Step 4.
  4. Verify that node3 and node4 belong to the same cluster by entering the following command and examining the output:
    cluster show
  5. Verify that node3 and node4 can access each other’s storage by entering the following command and examining the output:
    storage failover show -fields local-missing-disks,partner-missing-disks
  6. Verify that neither node3 nor node4 owns data LIFs home-owned by other nodes in the cluster by entering the following command and examining the output:
    network interface show
    If either node3 or node4 owns data LIFs home-owned by other nodes in the cluster, use the network interface revert command to revert the data LIFs to their home-owner.
  7. Verify that node3 owns the aggregates from node1 and that node4 owns the aggregates from node2:
    storage aggregate show -owner-name <node3>
    storage aggregate show -owner-name <node4>
  8. Determine whether any volumes are offline:
    volume show -node <node3> -state offline
    volume show -node <node4> -state offline
  9. If any volumes are offline, compare them with the list of offline volumes that you captured in Step 19 (d) in Prepare the nodes for upgrade, and bring online any of the offline volumes, as required, by entering the following command, once for each volume:
    volume online -vserver <vserver-name> -volume <volume_name>
  10. Install new licenses for the new nodes by entering the following command for each node:
    system license add -license-code <license_code,license_code,license_code…​>
    The license-code parameter accepts a list of 28 upper-case alphabetic character keys. You can add one license at a time, or you can add multiple licenses at once, each license key separated by a comma.
  11. If NetApp Storage Encryption (NSE) was in use on the configuration and you set the setenv bootarg.storageencryption.support command to "true" with the kmip.init.maxwait variable "off" (in Step 16 of Install and boot node3), you need to reset the variable:
    set diag; systemshell -node <node-name> -command sudo kenv -u -p kmip.init.maxwait
  12. To remove all of the old licenses from the original nodes, enter one of the following commands:
    system license clean-up -unused -expired
    system license delete -serial-number <node_serial_number> -package <licensable_package>
    • To delete all expired licenses, enter:
      system license clean-up -expired
    • To delete all unused licenses, enter:
    • To delete a specific license from a cluster, enter the following commands on the nodes:
      system license delete -serial-number <node1-serial-number> -package *
      system license delete -serial-number <node2-serial-number> -package *
      The following output is displayed:
      Warning: The following licenses will be removed:
      <list of each installed package>
      Do you want to continue? {y|n}: y
      Enter y to remove all of the packages.
  13. Verify that the licenses are properly installed by entering the following command and examining its output:
    system license show
    You might want to compare the output with the output that you captured in Step 30 of Prepare the nodes for upgrade.
  14. Configure the SPs by performing the following command on both nodes:
    system service-processor network modify -node <node-name>
    Go to References to link to the System Administration Reference for information about the SPs and the ONTAP 9 Commands: Manual Page Reference for detailed information about the system service- processor network modify command.
  15. Take the following actions on one of the new nodes:
    1. Enter advanced privilege level by entering the following command:
      set -privilege advanced
    2. Enter the following command:
      storage failover modify -node <node-name> -cifs-ndo-duration default|medium|low
      • Enter medium if the system will have workloads in which 50 percent to 75 percent of the operations will be 4 KB or smaller.
      • Enter low if the system will have workloads in which 75 percent to 100 percent of the operations will be 4 KB or smaller.
    3. Return to the admin level by entering the following command:
      set -privilege admin
    4. Reboot the system to ensure that the changes take effect.
  16. If you want to set up a switchless cluster on the new nodes, go to References to link to the Network Support Site and follow the instructions in Transitioning to a two-node switchless cluster.
After you finish
If Storage Encryption is enabled on node3 and node4, complete the steps in Set up Storage Encryption on the new controller module. Otherwise, complete the steps in Decommission the old system.
