LIFs are on invalid ports after upgrade
Contributors netapp-pcarriga netapp-thomi Download PDF of this page
After the upgrade is completed, the FC logical interfaces (LIFs) might be left on incorrect ports if you have a MetroCluster configuration. You can perform a resync operation to reassign the LIFs to the correct ports.
Step
  1. Enter the metrocluster vserver resync command to reallocate the LIFs to the correct ports.
    metrocluster vserver resync -vserver <vserver_name> fcp-mc.headupgrade.test.vs
