Retire node1
Contributors netapp-thomi Download PDF of this page
To retire node1, you need to disable the HA pair with node2, shut node1 down properly, and remove it from the rack or chassis.
Steps
  1. Verify the number of nodes in the cluster:
    cluster show
    The system displays the nodes in the cluster, as shown in the following example:
    cluster::> cluster show
    Node                  Health  Eligibility
    node1                 true    true
    node2                 true    true
    2 entries were displayed.
  2. Disable storage failover, as applicable:
    If the cluster is…​ Then…​
    A two-node cluster
    1. Disable cluster high availability by entering the following command on either node:
    cluster ha modify -configured false
    1. Disable storage failover:
    storage failover modify -node <node1> -enabled false
    A cluster with more than two nodes
  3. Verify that storage failover was disabled:
    storage failover show
    The following example shows the output of the storage failover show command when storage failover has been disabled for a node:
     cluster::> storage failover show
                                   Takeover
     Node           Partner        Possible State Description
     node1          node2          false    Connected to node2, Takeover
                                            is not possible: Storage failover is
                                            disabled
     node2          node1          false    Node owns partner's aggregates as part
                                            of the nondisruptive controller upgrade
                                            procedure. Takeover is not possible:
                                            Storage failover is disabled
  4. Verify the data LIF status:
    network interface show -role data -curr-node <node2> -home-node <node1>
    Look in the Status Admin/Oper column to see if any LIFs are down. If any LIFs are down, consult the Troublehsoot section.
  5. Take one of the following actions:
    A two-node cluster
    Go to Step 6.
    Go to Step 8.
  6. Access the advanced privilege level on either node:
    set -privilege advanced
  7. Verify that the cluster HA has been disabled:
    cluster ha show
    The system displays the following message:
    High Availability Configured: false
    If cluster HA has not been disabled, repeat Step 2.
  8. Check whether node1 currently holds epsilon:
    cluster show
    Because there is the possibility of a tie in a cluster that has an even number of nodes, one node has an extra fractional voting weight called epsilon. Refer to References to link to the System Administration Reference for more information.
    If you have a four-node cluster, epsilon might be on a node in a different HA pair in the cluster.
    The following example shows that node1 holds epsilon:
     cluster::*> cluster show
     Node                 Health  Eligibility  Epsilon
     node1                true    true         true
     node2                true    true         false
  9. If node1 holds epsilon, then mark epsilon false on the node so that it can be transferred to the node2:
    cluster modify -node <node1> -epsilon false
  10. Transfer epsilon to node2 by marking epsilon true on node2:
    cluster modify -node <node2> -epsilon true
  11. Verify that the change to node2 occurred:
    cluster show
     node1                true    true         false
     node2                true    true         true
    The epsilon for node2 should now be true and the epsilon for node1 should be false.
  12. Verify whether the setup is a two-node switchless cluster:
    network options switchless-cluster show
     cluster::*> network options switchless-cluster show
     Enable Switchless Cluster: false/true
    The value of this command must match the physical state of the system.
  13. Return to the admin level:
    set -privilege admin
  14. Halt node1 from the node1 prompt:
    system node halt -node <node1>
    Attention: If node1 is in same chassis as node2, do not power off the chassis by using the power switch or by pulling the power cable. If you do so, node2, which is serving data, will go down.
  15. When the system prompts you to confirm that you want to halt the system, enter y.
    The node stops at the boot environment prompt.
  16. When node1 displays the boot environment prompt, remove it from the chassis or the rack.
    You can decommission node1 after the upgrade is completed. See Decommission the old system.
