Retire node2
Contributors netapp-pcarriga netapp-thomi Download PDF of this page
To retire node2, you need to shut node2 down properly and remove it from the rack or chassis. If the cluster is in a SAN environment, you also need to delete the SAN LIFs.
Steps
  1. Take one of the following actions:
    If the cluster is…​ Then…​
    A two-node cluster
    Go to Step 2.
    A cluster with more than two nodes
    Go to Step 9.
  2. Access the advanced privilege level by entering the following command on either node:
    set -privilege advanced
  3. Verify that the cluster HA has been disabled by entering the following command and examining its output:
    cluster ha show
    The system displays the following message:
    High Availability Configured: false
  4. Check if node2 currently holds epsilon by entering the following command and examining its output:
    cluster show
    The following example shows that node2 holds epsilon:
    cluster*::> cluster show
    Node                 Health  Eligibility   Epsilon
    node1                true    true          false
    node2                true    true          true
    Warning: Cluster HA has not been configured. Cluster HA must be configured on a two-node cluster to ensure data access availability in the event of storage failover. Use the "cluster ha modify -configured true" command to configure cluster HA.
    2 entries were displayed.
  5. If node2 holds epsilon, mark epsilon as false on the node so that it can be transferred to node3:
    cluster modify -node <node2> -epsilon false
  6. Transfer epsilon to node3 by marking epsilon true on node3:
    cluster modify -node <node3> -epsilon true
  7. Verify if the setup is a two-node switchless cluster:
    network options switchless-cluster show
    cluster::*> network options switchless-cluster show
    Enable Switchless Cluster: false/true
    The value of this command must match the physical state of the system.
  8. Verify if the setup is a two-node switchless cluster:
  9. Return to the admin level:
    set -privilege admin
  10. Halt node2 by entering the following command on either controller:
    system node halt -node <node2>
  11. After node2 shuts down completely, remove it from the chassis or the rack. You can decommission node2 after the upgrade is completed. See Decommission the old system.
