Stage 6: Complete the upgrade
Contributors netapp-thomi netapp-pcarriga Download PDF of this page
During Stage 6, you ensure that the new nodes are set up correctly. If one of the new nodes has a unified target adapter, you must restore any port configurations and might need to change the personality of the adapter. You also should set up Storage Encryption if the new nodes are encryption-enabled. You also should decommission the old nodes.
