Get an IP address of an external key management server for Storage Encryption
Contributors netapp-thomi Download PDF of this page
After upgrading, you must immediately configure Storage Encryption and establish a cluster-wide authentication key to replace the previous node-level authentication keys.
Steps
  1. Install the necessary client and server secure sockets layer (SSL) certificates required to communicate with key management servers:
    security certificate install
  2. Configure Storage Encryption on all nodes by using the following command on each node:
    security key-manager setup
  3. Add the IP address for each key management server:
    security key-manager add
  4. Verify that the same key management servers are configured and available on all nodes in the cluster:
    security key-manager show -status
  5. Create a new cluster-wide authentication key:
    security key-manager create-key
  6. Make a note of the new authentication key ID.
  7. Rekey all self-encrypting drives with the new authentication key:
    storage encryption disk modify -disk * -data-key-id <authentication_key_id>
