Verify the health of the MetroCluster configuration
Contributors netapp-pcarriga netapp-thomi Download PDF of this page
You should check the health of the MetroCluster configuration to verify proper operation.
Steps
  1. Verify that the MetroCluster components are healthy:
    metrocluster check run
    cluster_A::> metrocluster check run
    Last Checked On: 10/1/2017 16:03:37
    Component           Result
    nodes               ok
    lifs                ok
    config-replication  ok
    aggregates          ok
    4 entries were displayed.
    Command completed. Use the "metrocluster check show -instance" command or sub-commands in "metrocluster check" directory for detailed results.
    To check if the nodes are ready to do a switchover or switchback operation, run "metrocluster switchover -simulate" or "metrocluster switchback -simulate", respectively.
  2. Verify that there are no health alerts:
    system health alert show
