NetApp Technical Reports
Maximums and limits
Contributors whyistheinternetbroken elliott-ecton
The following section covers the maximums and minimums of a NetApp AFX cluster as compared to unified ONTAP.
For the most recent limits, see Hardware Universe.
NetApp AFX maximums and minimums
Limit Unified ONTAP NetApp AFX
Volume count (cluster)
  • 30,000 (platform dependent)
  • 30,000
Aggregate size
  • 800TB
  • N/A
Node count
  • 24
  • 8 (9.17.1)
  • 32 (9.19.1RC1)
Total capacity
  • 2PB (9.17.1)
  • 3PB (9.18.1RC1)
  • 16PB (9.18.1GA release)
  • 20PB (9.19.1RC0)
  • 32PB (9.19.1RC1)
Supported shelf count
  • 8 per HA pair
  • 192 per cluster
  • 12 per cluster (9.18.1GA)
  • 17 per cluster (9.19.1RC0)
  • 25 per cluster (9.19.1RC1) (no HA pair limitation)
Total supported drive count
  • 240 per HA pair
  • 2880 (24 nodes)
  • 288 per cluster (based on shelf count limits; no HA pair limitation)
  • 408 per cluster (9.19.1RC0)
  • 600 per cluster (9.19.1RC1)
Volume size
  • 300TB (FlexVol)
  • 60PB (FlexGroup)
  • 300TB (FlexVol)
  • 60PB (FlexGroup)*
Maximum files per volume
  • 2 billion (FlexVol)
  • 400 billion (FlexGroup)
Maximum files per directory (default 320MB maxdirsize value)
  • ~4 million (FlexVol)
  • ~2 million (FlexGroup)
SnapMirror concurrent transfers
  • 250
  • 250
Number of qtrees
  • 4096
  • 4096
Maximum TCP connections per node
  • 100,000
  • 100,000
Maximum locks per node
  • 3 million
  • 3 million
Maximum data interface count (cluster)
  • 4096
  • 4096
Maximum constituent count – FlexGroup
  • 200
  • 200
  • 512 in 9.19.1 RC1
Maximum number of intercluster LIFs
  • 8
  • 8
Maximum number of IP spaces
  • 512
  • 512
Maximum number of FlexCache per origin
  • 100
  • 100
Max number of FlexCache (node)
  • 400
  • 400
