Maximums and limits
The following section covers the maximums and minimums of a NetApp AFX cluster as compared to unified ONTAP.
For the most recent limits, see Hardware Universe.
NetApp AFX maximums and minimums
| Limit | Unified ONTAP | NetApp AFX |
Volume count (cluster) |
Aggregate size |
Node count |
Total capacity |
Supported shelf count |
Total supported drive count |
Volume size |
Maximum FlexGroup constituent count |
Maximum files per volume |
Maximum files per directory (default 320MB maxdirsize value) |
SnapMirror concurrent transfers |
Number of qtrees |
Maximum TCP connections per node |
Maximum locks per node |
Maximum data interface count (cluster) |
Maximum number of intercluster LIFs |
Maximum number of IP spaces |
Maximum number of FlexCache per origin |
Max number of FlexCache (node) |
*FlexGroup maximum size will be limited to 32PB physical size.
