ONTAP Technical Reports
NFS over TLS overview
ONTAP 9.19.1 introduces NFS over TLS, the much-anticipated 'easy button' for encrypting your NFS traffic.
Prior to this feature, encrypting your NFS payload in flight was limited to IPsec or Kerberos. While both are effective, configuration was cumbersome and performance penalties could soar high. Both methods were 'bolt-on' solutions—​solutions not defined in an RFC specifically for NFS. RFC 9289, titled "Toward Remote Procedure Call Encryption by Default" changed that. Now NFSv3 and NFSv4.x can encrypt NFS RPC traffic in flight using TLS 1.3. No Kerberos required. No IPsec required.
Prerequisites
To use ONTAP NFS over TLS, you must meet the following requirements.
  • …​be running ONTAP 9.19.1
    • ONTAP cloud personalities are not supported at this time
  • …​have NFS licensed
  • …​have an NFS client found in the NetApp Interoperability Matrix
What it doesn't do
NFS over TLS secures the transport layer — it does not change how NFS authenticates users.
Certificate-based user authentication. NFS over TLS does not provide a new user authentication mechanism. You still need either auth_sys or krb5 for user authentication. You can still use krb5i and krb5p, but TLS makes their integrity and privacy protections redundant—​and you'll still take the performance hit.
