ONTAP Technical Reports
Performance
TLS adds cost in three resource dimensions: CPU, memory, and network.
Resource cost overview
CPU is the primary cost. The TLS 1.3 handshake is a one-time, per-connection expense covering asymmetric cryptography, certificate parsing, and key exchange. Once a connection is established, steady-state overhead is symmetric record encryption using AES-GCM or ChaCha20-Poly1305. On platforms equipped with Mellanox ConnectX-6 Dx (CX6-Dx) or ConnectX-7 (CX7) NICs, the NIC itself performs encryption and decryption via kernel TLS (KTLS) offload, materially reducing the steady-state CPU cost.
Memory impact is low. TLS adds per-connection session state and a per-node TLS configuration cache. Cache size is bounded; entries are aged by Time-To-Live (TTL) and refreshed in the background.
Network overhead is small. TLS 1.3 record framing adds a fixed per-record overhead and an authentication tag. The handshake adds round-trips at connection setup only, not per RPC.
TLS performance penalty
There are two distinct paths for NFS over TLS in ONTAP: the hardware offload path and the software TLS path. The hardware offload path is available on platforms with CX6-Dx or CX7 NICs. The software TLS path is used on platforms without offload-capable NICs.
On platforms with offload-capable NICs, performance was observed to be within approximately 10% of plain-text NFS across a range of workloads. On platforms without offload-capable NICs, the software TLS path is more workload-sensitive and can show throughput reductions of approximately 30% compared to plain-text NFS in the worst case. These are characterization numbers, not guaranteed specs. Your results will vary based on workload type, I/O size, and connection count. If you're mixing TLS and non-TLS traffic on the same node, expect some impact on non-TLS throughput as well.
Scaling factors
The following factors increase aggregate TLS CPU cost or handshake latency:
Connection churn. Every new connection pays the handshake cost. Workloads that frequently open and close TCP connections to the NFS server see higher aggregate TLS CPU than workloads with long-lived connections.
Mount storms after takeover or network event. Workloads where many clients reconnect simultaneously—​such as after an HA takeover—​pay the full TLS 1.3 handshake cost per connection. Monitor nfs_tls:tls_handshake_average_latency and plan connection headroom accordingly.
Large numbers of distinct client identities (mutual TLS). Mutual TLS (mTLS) deployments scale handshake CPU with the number of unique client certificates being validated.
mTLS vs. server-only TLS. Enabling host authentication (mTLS) adds client-certificate validation on the server side, making each handshake moderately more expensive than server-only TLS. Steady-state per-RPC cost is unchanged.
TLS configuration churn. Frequent changes to TLS interface configuration—​certificate rotation, enable/disable cycles—​invalidate the per-node TLS configuration cache and force lookups back to the management host, briefly raising handshake latency.
