ONTAP Technical Reports
Interoperability and limits
NFS over TLS composes with standard ONTAP export-policy controls, replicates through SVM-DR and MetroCluster, and carries a small set of hard platform limitations and operational recommendations you should know before deploying.
Interoperability
Supported co-existing features
Export policies, qtree exports, and junction paths.
The export-policy rule gains the -allow-nfs-tls-only field, which can require TLS on a per-rule basis. It composes with existing client-match, protocol, read-only/read-write, superuser, anonymous, chown-mode, allow-suid, and NTFS-UNIX security controls. Qtree exports and junction-path mounts inherit the TLS requirement through the same export-policy mechanism. System Manager surfaces the -allow-nfs-tls-only setting in the NFS access picker.
NFS over TLS replication and DR support is summarized in the table below. For background on the replication mechanism, see Architecture.
Table 1. Replication and DR support matrix
Replication / DR NFS over TLS at 9.19.1
SVM-DR
Supported. TLS interface row replicates at SVM scope (status, certificate name and UUID, enforce-host-auth). The -allow-nfs-tls-only export-rule field replicates with the export policy.
MetroCluster (SVM-level replication)
Supported. Same replication path as SVM-DR. Certificate-material lifecycle on the destination SVM is owned by the certificate manager.
SnapMirror (volume replication)
Supported. Orthogonal to client-side TLS transport.
Cloud-hosted ONTAP variants
Not supported at 9.19.1.
Features with constraints
Client requirements.
The NFS client must implement TLS for ONC RPC per RFC 9289. On Linux, this is provided by an in-kernel NFS client that supports the xprtsec=tls (or xprtsec=mtls) mount option, used in combination with the userspace TLS handshake helper tlshd from the ktls-utils package. For the definitive client matrix—​including minimum kernel versions, userspace package versions, and supported Linux distributions—​consult the Interoperability Matrix Tool (IMT).
Limitations and caveats
  • Cloud-hosted ONTAP variants. Cloud Volumes ONTAP and other cloud-hosted ONTAP variants are not supported at ONTAP 9.19.1.
  • NFS over Remote Direct Memory Access (RDMA). NFS-over-RDMA and NFS over TLS are mutually exclusive on the same LIF.
Per-node limits
Important There are currently no hard-coded connection limits for NFS-over-TLS in ONTAP. For the latest information on supported limits, refer to Hardware Universe.
BEST PRACTICE: Keep the per-node NFS-over-TLS connection count below 10,000 to maintain headroom for mount storms and HA takeovers.
Per-cluster limits
There's no separate cluster-wide aggregate cap enforced in code.
Per-LIF and per-object limits
  • The configuration table is keyed on the (SVM, LIF) tuple. Each LIF carries either zero or one NFS-over-TLS configuration row.
  • Exactly one server certificate is bound per NFS-over-TLS-enabled LIF. The certificate is specified at vserver nfs tls interface enable time and can be changed with …​ modify -certificate-name.
  • -allow-nfs-tls-only is a single boolean per export-policy rule. This feature adds no separate rule-count ceiling; standard per-policy and per-SVM export-rule maximums apply.
Enforcement behavior
-allow-nfs-tls-only true enforcement.
When this field is true on a matched export-policy rule, NFS connection attempts from matched clients that are not using TLS for ONC RPC per RFC 9289 are rejected at export-rule evaluation. Existing TLS connections from those clients are unaffected.
-enforce-host-auth true enforcement.
When true on a (SVM, LIF), TLS handshakes whose client certificate identity does not match the configured host identity for the LIF are rejected during the TLS handshake. The EMS event Nblade.TLSHandshakeFailed (severity ERR, rate-limited once per 10 minutes per event source) is emitted for each failed handshake.
EMS rate limits.
Nblade.TLSConfigError and Nblade.TLSHandshakeFailed are rate-limited to once per 10 minutes per event source. Nblade.NfsTlsDisabled is rate-limited to once per 24 hours per event source. These are intentional ceilings on event-log volume during sustained failure conditions. During a burst, only the first occurrence within each rate-limit window is recorded.
Soft limits and recommendations
The following are recommendations, not hard maximums.
  • Maintain headroom below 10,000 NFS-over-TLS connections per node. There's no hard-coded cap, but keep your per-node NFS-over-TLS connection count at or below 10,000.
  • Plan for full TLS re-handshake after HA takeover. TLS sessions are TCP-scoped and don't survive a takeover. Every client will reconnect with a fresh TLS 1.3 handshake on the surviving or destination node, so plan for a mount storm. Keeping your connection count well below 10,000 gives you headroom to absorb that burst.
