NetApp Technical Reports
ONTAP roles, applications, and authentication
Contributors netapp-dbagwell netapp-chrisgeb
ONTAP provides the security-conscious enterprise with the ability to provide granular access to different administrators through different login applications and methods. This helps customers create a data centric zero-trust model.
These are the roles available for admin and storage virtual machine administrators. The login application methods and login authentication methods are specified.
Roles
With role-based access control (RBAC), users have access to only the systems and options required for their job roles and functions. The RBAC solution in ONTAP limits users' administrative access to the level granted for their defined role, which allows administrators to manage users by assigned role. ONTAP provides several predefined roles. Operators and administrators can create, modify, or delete custom access control roles, and they can specify account restrictions for specific roles.
Predefined roles for cluster administrators
This role…​
Has this level of access…​
To the following commands or command directories
admin
All
All command directories (DEFAULT)
admin-no-fsa (available beginning with ONTAP 9.12.1)
Read/Write
  • All command directories (DEFAULT)
  • security login rest-role
  • security login role
Read only
  • security login rest-role create
  • security login rest-role delete
  • security login rest-role modify
  • security login rest-role show
  • security login role create
  • security login role delete
  • security login role modify
  • security login role show
  • volume activity-tracking
  • volume analytics
None
volume file show-disk-usage
autosupport
All
  • set
  • system node autosupport
None
All other command directories (DEFAULT)
backup
All
vserver services ndmp
Read only
volume
None
readonly
All
  • security login password
    For managing own user account local password and key information only
  • set
None
security
Read only
none
None
Note The autosupport role is assigned to the predefined autosupport account, which is used by AutoSupport OnDemand. ONTAP prevents you from modifying or deleting the autosupport account. ONTAP also prevents you from assigning the autosupport role to other user accounts.
Predefined roles for storage virtual machine (SVM) administrators
Role name
Capabilities
vsadmin
  • Manage own user account local password and key information
  • Manage volumes, except volume moves
  • Manage quotas, qtrees, snapshots, and files
  • Manage LUNs
  • Perform SnapLock operations, except privileged delete
  • Configure protocols: NFS, SMB, iSCSI, FC, FCoE, NVMe/FC and NVMe/TCP
  • Configure services: DNS, LDAP, and NIS
  • Monitor jobs
  • Monitor network connections and network interface
  • Monitor the health of the SVM
vsadmin-volume
  • Manage LUNs
  • Monitor network interface
vsadmin-protocol
  • Manage LUNs
vsadmin-backup
  • Manage NDMP operations
  • Make a restored volume read/write
  • Manage SnapMirror relationships and snapshots
  • View volumes and network information
vsadmin-snaplock
  • Perform SnapLock operations, including privileged delete
  • Configure protocols: NFS and SMB
  • Monitor jobs
vsadmin-readonly
  • View volumes and LUNs
  • View services and protocols
Application methods
The application method specifies the access type of the login method. Possible values include console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
Setting this parameter to service-processor grants the user access to the Service Processor. When this parameter is set to service-processor, the -authentication-method parameter must be set to password because the Service Processor only supports password authentication. SVM user accounts cannot access the Service Processor. Therefore, operators and administrators cannot use the -vserver parameter when this parameter is set to service-processor.
To further restrict access to the service-processor use the command system service-processor ssh add-allowed-addresses. The command system service-processor api-service can be used to update the configurations and certificates.
For security reasons, Telnet and Remote Shell (RSH) are disabled by default because NetApp recommends Secure Shell (SSH) for secure remote access. If there is a requirement or unique need for Telnet or RSH, they must be enabled.
The security protocol modify command modifies the existing cluster-wide configuration of RSH and Telnet. Enable RSH and Telnet in the cluster by setting the enabled field to true.
Authentication methods
The authentication method parameter specifies the authentication method used for logins.
Authentication method Description
cert
SSL certificate authentication
community
SNMP community strings
domain
Active Directory authentication
nsswitch
LDAP or NIS authentication
password
Password
publickey
Public key authentication
usm
SNMP user security model
Note The use of NIS is not recommended due to protocol security weaknesses.
Beginning with ONTAP 9.3, chained two-factor authentication is available for local SSH admin accounts using publickey and password as the two authentication methods. In addition to the -authentication-method field in the security login command, a new field named -second-authentication-method has been added. Either publickey or password can be specified as the -authentication-method or the -second-authentication-method. However, during SSH authentication, the order is always publickey with partial authentication, followed by the password prompt for full authentication.
[user@host01 ~]$ ssh ontap.netapp.local
Authenticated with partial success.
Password:
cluster1::>
Beginning with ONTAP 9.4, nsswitch can be used as a second authentication method with publickey.
Beginning with ONTAP 9.12.1, FIDO2 can also be used for SSH authentication using a YubiKey hardware authentication device or other FIDO2 compatible devices.
Beginning with ONTAP 9.13.1:
  • domain accounts can be used as a second authentication method with publickey.
  • Time-based one-time password (totp) is a temporary passcode generated by an algorithm that uses the current time of day as one of its authentication factors for the second authentication method.
  • Public key revocation is supported with SSH publickeys as well as certificates which will be checked for expiration/revocation during SSH.
For more information about multifactor authentication (MFA) for ONTAP System Manager, Active IQ Unified Manager, and SSH, see TR-4647: Multifactor Authentication in ONTAP 9.
