NetApp Technical Reports
Zero Trust and hybrid cloud deployments
Contributors netapp-chrisgeb netapp-dbagwell
NetApp is the data authority for the hybrid cloud. NetApp offers a variety of options for extending on-premises data management systems to the hybrid cloud with Amazon Web Services (AWS), Microsoft Azure, Google Cloud, and other leading cloud providers. NetApp hybrid-cloud solutions support the same Zero Trust security controls that are available with on-premises ONTAP systems and ONTAP Select software-defined storage.
You can easily expand capacity in public clouds without typical CAPEX constraints by using enterprise-class, cloud-native file services for AWS (FSxN), Google Cloud (GCNV), and Azure NetApp Files for Microsoft Azure. Ideal for data-intensive workloads such as analytics and DevOps, these cloud data services combine elastic, on-demand storage as a service from NetApp with ONTAP data management in a fully managed offering.
ONTAP enables the movement of data between your on-premises ONTAP systems and AWS, Google Cloud, or Azure storage environment with NetApp SnapMirror data replication software.
