Create a SnapMirror endpoint
You must create a SnapMirror endpoint before you can create a replication relationship. You can perform this task in the Element software web UI only.
Before you begin
You must have enabled SnapMirror on the Element cluster.
Steps
Click Data Protection > SnapMirror Endpoints.
Click Create Endpoint.
In the Create a New Endpoint dialog, enter the ONTAP cluster management IP address.
Enter the user ID and password of the ONTAP cluster administrator.
