Configure HDFAs and ONTAP data LIFs
You'll need to configure the HDFA and the data LIFs appropriately to realize the benefits of this hotspot remediation solution. This solution uses intracluster caching with the origin and HDFA in the same cluster.
The following are two HDFA sample configurations:
2x2x2 inter-SVM HDFA
4x1x4 intra-SVM HDFA
Perform this advanced configuration using the ONTAP CLI. There are two configurations you must use in the flexcache create command, and one configuration you must make sure isn't configured:
-aggr-list: Provide an aggregate, or list of aggregates, that reside on the node or subset of nodes you want to restrict the HDF to. -
-aggr-list-multiplier: Determine how many constituents will be created per aggregate listed in theaggr-listoption. If you have two aggregates listed, and set this value to2, you will end up with four constituents. NetApp recommends up to 8 constituents per aggregate, but 16 is also sufficient. -
-auto-provision-as: If you tab out, the CLI will try to autofill and set the value toflexgroup. Make sure this isn't configured. If it appears, delete it.
Create a 2x2x2 inter-SVM HDFA configuration
To assist in configuring a 2x2x2 inter-SVM HDFA as shown in Figure 1, complete a prep sheet.
Figure 1: 2x2x2 Inter-SVM HDFA layout
SVM Nodes per HDF Aggregates Constituents per node Junction path Data LIF IPs svm1
node1, node2
aggr1, aggr2
2
/hotspot
192.168.0.11,192.168.0.12
svm2
node3, node4
aggr3, aggr4
2
/hotspot
192.168.0.13,192.168.0.14
Create the HDFs. Run the following command twice, once for each row in the prep sheet. Make sure you adjust the
vserverandaggr-listvalues for the second iteration.cache::> flexcache create -vserver svm1 -volume hotspot -aggr-list aggr1,aggr2 -aggr-list-multiplier 2 -origin-volume <origin_vol> -origin-vserver <origin_svm> -size <size> -junction-path /hotspot
Create the data LIFs. Run the command four times, creating two data LIFs per SVM on the nodes listed in the prep sheet. Make sure you adjust the values appropriately for each iteration.
cache::> net int create -vserver svm1 -home-port e0a -home-node node1 -address 192.168.0.11 -netmask-length 24
What's nextNow you need to configure your clients to utilize the HDFA appropriately. See client configuration.
Create a 4x1x4 intra-SVM HDFA
To assist in configuring a 4x1x4 inter-SVM HDFA as shown in figure 2, fill out a prep sheet.
Figure 2: 4x1x4 intra-SVM HDFA layout
node1
aggr1
4
/hotspot1
192.168.0.11
svm1
node2
aggr2
4
/hotspot2
192.168.0.12
svm1
node3
aggr3
4
/hotspot3
192.168.0.13
svm1
node4
aggr4
4
/hotspot4
192.168.0.14
Create the HDFs. Run the following command four times, once for each row in the prep sheet. Make sure you adjust the
aggr-listandjunction-pathvalues for each iteration.cache::> flexcache create -vserver svm1 -volume hotspot1 -aggr-list aggr1 -aggr-list-multiplier 4 -origin-volume <origin_vol> -origin-vserver <origin_svm> -size <size> -junction-path /hotspot1
Create the data LIFs. Run the command four times, creating a total of four data LIFs in the SVM. There should be one data LIF per node. Make sure you adjust the values appropriately for each iteration.
