ONTAP FPolicy external engine configuration worksheets
Contributors netapp-barbe netapp-forry netapp-thomi netapp-aherbin
You can use this worksheet to record the values that you need during the FPolicy external engine configuration process. If a parameter value is required, you need to determine what value to use for those parameters before you configure the external engine.
Information for a basic external engine configuration
You should record whether you want to include each parameter setting in the external engine configuration and then record the value for the parameters that you want to include.
Type of information
Required
Include
Your values
Storage virtual machine (SVM) name
Yes
Yes
Engine name
Yes
Yes
Primary FPolicy servers
Yes
Yes
Port number
Yes
Yes
Secondary FPolicy servers
No
External engine type
No
SSL option for communication with external FPolicy server
Yes
Yes
Certificate FQDN or custom common name
No
Certificate serial number
No
Certificate authority
No
Information for advanced external engine parameters
To configure an external engine with advanced parameters, you must enter the configuration command while in advanced privilege mode.
Type of information
Required
Include
Your values
Timeout for canceling a request
No
Timeout for aborting a request
No
Interval for sending status requests
No
Maximum outstanding requests on the FPolicy server
No
Timeout for disconnecting a nonresponsive FPolicy server
No
Interval for sending keep-alive messages to the FPolicy server
No
Maximum reconnect attempts
No
Receive buffer size
No
Send buffer size
No
Timeout for purging a session ID during reconnection
No
