Commands for diagnosing network problems
Download PDF of this page
You can diagnose problems on your network by using commands such as ping, traceroute, ndp, and tcpdump. You can also use commands such as ping6 and traceroute6 to diagnose IPv6 problems.
If you want to…​ Enter this command…​
Test whether the node can reach other hosts on your network
network ping
Test whether the node can reach other hosts on your IPv6 network
network ping6
Trace the route that the IPv4 packets take to a network node
network traceroute
Trace the route that the IPv6 packets take to a network node
network traceroute6
Manage the Neighbor Discovery Protocol (NDP)
network ndp
Display statistics about packets that are received and sent on a specified network interface or on all network interfaces
run -node node_name ifstat
Note: This command is available from the nodeshell.
Display information about neighboring devices that are discovered from each node and port in the cluster, including the remote device type and device platform
network device-discovery show
View the CDP neighbors of the node (ONTAP supports only CDPv1 advertisements)
run -node node_name cdpd show-neighbors
Trace the packets that are sent and received in the network
network tcpdump start -node node-name - port port_name
Measure latency and throughput between intercluster or intracluster nodes
network test-path -source-node source_nodename
local -destination- cluster destination_clustername - destination-node destination_nodename - session-type Default
AsyncMirrorLocal
AsyncMirrorRemote
SyncMirrorRemote
For more information about these commands, see the appropriate man pages.
Related information
