Worksheet for NAS path failover configuration
Download PDF of this page
You should complete all sections of the worksheet before configuring NAS path failover.
IPspace configuration
You can use an IPspace to create a distinct IP address space for each SVM in a cluster. Doing so enables clients in administratively separate network domains to access cluster data while using overlapping IP addresses from the same IP address subnet range.
Information | Required? | Your values |
IPspace name |
Yes |
Broadcast domain configuration
A broadcast domain groups ports that belong in the same Layer 2 network and sets the MTU for the broadcast domain ports.
Broadcast domains are assigned to an IPspace. An IPspace can contain one or more broadcast domains.
The port to which a LIF fails over must be a member of the failover group for the LIF. For each broadcast domain created by ONTAP, a failover group with the same name is also created that contains all the ports in the broadcast domain. |
IPspace name |
Yes |
Broadcast domain name |
Yes |
MTU |
Yes |
Ports |
Yes |
Subnet configuration
A subnet contains pools of IP addresses and a default gateway that can be assigned to LIFs used by SVMs residing in the IPspace.
When creating a LIF on an SVM, you can specify the name of the subnet instead of supplying an IP address and a subnet.
Since a subnet can be configured with a default gateway, you do not have to create the default gateway in a separate step when creating an SVM.
A broadcast domain can contain one or more subnets.
You can configure SVM LIFs that are on different subnets by associating more than one subnet with the IPspace’s broadcast domain.
Each subnet must contain IP addresses that do not overlap with IP addresses assigned to other subnets in the same IPspace.
You can assign specific IP addresses to SVM data LIFs and create a default gateway for the SVM instead of using a subnet.
IPspace name |
Yes |
Subnet name |
Yes |
Yes |
Subnet name and mask |
Yes |
Gateway |
No |
IP address ranges |
No |
Force update of LIF associations |
No |
SVM configuration
You use SVMs to serve data to clients and hosts.
The values you record are for creating a default data SVM. If you are creating a MetroCluster source SVM, see the Fabric-attached MetroCluster Installation and Configuration Guide or the Stretch MetroCluster Installation and Configuration Guide.
SVM name |
Yes |
Root volume name |
Yes |
Aggregate name |
Yes |
Security style |
Yes |
IPspace name |
No |
SVM language setting |
No |
LIF configuration
An SVM serves data to clients and hosts through one or more network logical interfaces (LIFs).
SVM name |
Yes |
LIF name |
Yes |
Service policy |
Yes |
Allowed protocols |
No |
Home node |
Yes |
Home port or broadcast domain |
Yes |
Subnet name |
Yes (if using a subnet) |
DNS configuration
You must configure DNS on the SVM before creating an NFS or SMB server.
SVM name |
Yes |
DNS domain name |
Yes |
IP addresses of the DNS servers |
Yes |
Dynamic DNS configuration
Before you can use dynamic DNS to automatically add DNS entries to your Active Directory- integrated DNS servers, you must configure dynamic DNS (DDNS) on the SVM.
DNS records are created for every data LIF on the SVM. By creating multiple data LIFS on the SVM, you can load-balance client connections to the assigned data IP addresses. DNS load balances connections that are made using the host name to the assigned IP addresses in a round- robin fashion.
SVM name |
Yes |
Whether to use DDNS |
Yes |
Whether to use secure DDNS |
No |
FQDN of the DNS domain |
No |
