Display NIS statistics for ONTAP NFS SVMs
You can display NIS statistics for storage virtual machines (SVMs) on the storage system to monitor performance and diagnose issues.
Use the
statistics catalog object showcommand to identify the NIS objects from which you can view data.statistics catalog object show -object external_service_op* -
Use the
statistics startandstatistics stopcommands to collect a data sample from one or more objects. -
Use the
statistics showcommand to view the sample data.
Monitoring NIS statistics
The following examples display performance data for NIS queries. The following commands start data collection for a new sample:
vs1::*> statistics start -object external_service_op -sample-id nis_sample1 vs1::*> statistics start -object external_service_op_error -sample-id nis_sample2
The following command displays data from the sample by specifying counters that show the number of NIS queries sent versus the number of NIS queries received, failed, or timed out:
vs1::*> statistics show -sample-id nis_sample1 -counter instance|num_requests_sent|num_responses_received|num_successful_responses|num_timeouts|num_request_failures|num_not_found_responses
Object: external_service_op
Instance: vs1:NIS:Query:10.227.13.221
Start-time: 3/8/2016 11:27:39
End-time: 3/8/2016 11:27:56
Elapsed-time: 17s
Scope: vs1
Counter Value
num_not_found_responses 0
num_request_failures 1
num_requests_sent 2
num_responses_received 1
num_successful_responses 1
num_timeouts 0
6 entries were displayed.
The following command displays data from the sample by specifying counters that show the number of times a specific error was received for a NIS query on the particular server:
vs1::*> statistics show -sample-id nis_sample2 -counter server_ip_address|error_string|count
Object: external_service_op_error
Instance: vs1:NIS:Query:YP_NOTFOUND:10.227.13.221
Start-time: 3/8/2016 11:33:05
End-time: 3/8/2016 11:33:10
Elapsed-time: 5s
Scope: vs1
Counter Value
count 1
error_string YP_NOTFOUND
server_ip_address 10.227.13.221
3 entries were displayed.
