ONTAP Active IQ Unified Manager worksheet
Before you install, configure, and connect Active IQ Unified Manager, you should have specific information about your environment readily available. You can record the information in the worksheet.
Unified Manager installation information
Virtual machine on which software is deployed |
Your value |
ESXi server IP address |
Host fully qualified domain name |
Host IP address |
Network mask |
Gateway IP address |
Primary DNS address |
Secondary DNS address |
Search domains |
Maintenance user name |
Maintenance user password |
Unified Manager configuration information
Setting |
Your value |
Maintenance user email address |
NTP server |
SMTP server host name or IP address |
SMTP user name |
SMTP password |
SMTP default port |
25 (Default value) |
Email from which alert notifications are sent |
LDAP bind distinguished name |
LDAP bind password |
Active Directory administrator name |
Active Directory password |
Authentication server base distinguished name |
Authentication server host name or IP address |
Cluster information
Capture the following information for each cluster on Unified Manager.
Cluster 1 of N |
Your value |
Host name or cluster-management IP address |
ONTAP administrator user name
ONTAP administrator password |
Protocol (HTTP or HTTPS) |
