Display information about ONTAP SMB restricted group GPOs
You can display detailed information about restricted groups that are defined as Group Policy Objects (GPOs) in Active Directory and that are applied to the CIFS server.
By default, the following information is displayed:
Group policy name
Group policy version
Link
Specifies the level in which the group policy is configured. Possible output values include the following:
Localwhen the group policy is configured in ONTAP -
Sitewhen the group policy is configured at the site level in the domain controller -
Domainwhen the group policy is configured at the domain level in the domain controller -
OrganizationalUnitwhen the group policy is configured at the Organizational Unit (OU) level in the domain controller -
RSOPfor the resultant set of policies derived from all the group policies defined at various levels
Restricted group name
The users and groups who belong to and who do not belong to the restricted group
The list of groups to which the restricted group is added
A group can be a member of groups other than the groups listed here.
Display information about all restricted group GPOs by performing one of the following actions:
If you want to display information about all restricted group GPOs… Enter the command… Defined in Active Directory
vserver cifs group-policy restricted-group show-defined -vserver vserver_nameApplied to a CIFS server
vserver cifs group-policy restricted-group show-applied -vserver vserver_name
The following example displays information about restricted group GPOs defined in the Active Directory domain to which the CIFS-enabled SVM named vs1 belongs:
cluster1::> vserver cifs group-policy restricted-group show-defined -vserver vs1
Vserver: vs1
Group Policy Name: gpo1
Version: 16
Link: OrganizationalUnit
Group Name: group1
Members: user1
MemberOf: EXAMPLE\group9
Group Policy Name: Resultant Set of Policy
Version: 0
Link: RSOP
Group Name: group1
Members: user1
The following example displays information about restricted groups GPOs applied to the CIFS-enabled SVM vs1:
cluster1::> vserver cifs group-policy restricted-group show-applied -vserver vs1
Vserver: vs1
Version: 16
Group Name: group1
Members: user1
Version: 0
Link: RSOP
Group Name: group1
Members: user1
