- ONTAP docs
- Release Notes
- System Manager integration with BlueXP
Introduction and concepts
ONTAP concepts
- Overview
- ONTAP platforms
- Cluster storage
- High-availability pairs
- AutoSupport and Active IQ Digital Advisor
Network architecture
- Client protocols
Disks and aggregates
- Volumes, qtrees, files, and LUNs
Storage virtualization
Path failover
- Load balancing
Replication
Storage efficiency
Security
- Application aware data management
- FabricPool
Set up, upgrade and revert ONTAP
Set up ONTAP
- Get started
- Set up a cluster with System Manager
Set up a cluster with the CLI
- Create the cluster on the first node
- Join remaining nodes to the cluster
- Convert management LIFs from IPv4 to IPv6
- Check your cluster with Active IQ Config Advisor
- Synchronize the system time across the cluster
- Commands for managing symmetric authentication on NTP servers
- Additional system configuration tasks to complete
Configure All SAN Array software
Upgrade ONTAP
- Overview
- When to upgrade ONTAP
Prepare for an ONTAP upgrade
- Preparation summary
- Choose your target ONTAP release
- Confirm configuration support
- Identify common configuration errors
- Upgrade paths
- Create an upgrade plan
- Verify LIF failover configuration
- Verify SVM routing configuration
Special considerations
- Summary of special considerations
- Mixed version clusters
- MetroCluster upgrade requirements
- SAN configurations
SnapMirror
- DP-type relationships
- Deduplicated volumes and aggregates
- NetApp Storage Encryption
- Netgroups
- LDAP clients using SSLv3
- Session-oriented protocols
- SSH public keys
- Load sharing mirrors (8.3)
- Reboot SP or BMC
- Download the ONTAP software image
ONTAP upgrade methods
What to do after an ONTAP upgrade
Firmware and system updates
Revert ONTAP
- Overview
- Do I need technical support?
- What are the revert paths?
What should I read before I revert?
- What should I verify before I revert?
What else should I check before I revert?
- How do I get and install the revert software image?
- Revert my cluster
What should I do after reverting my cluster?
- Verify cluster and storage health
- Enable automatic switchover for MetroCluster configurations
- Enable and revert LIFs to home ports
- Enable Snapshot copy policies
- Verify client access (SMB and NFS)
- Verify IPv6 firewall entries
- Revert password hash function
- Maually update SP firmware
- Verify user accounts that can access the Service Processor
Cluster administration
Cluster management with System Manager
- Administration overview
- Use System Manager to access a Cluster
- Enable new features
- Download a cluster configuration
- View and submit support cases
- Manage maximum capacity limit of a storage VM
- Monitor capacity with System Manager
- Manage AutoSupport with System Manager
- Monitor risks with Active IQ Digital Advisor
- Gain insights to help optimize your system
- View hardware configurations and determine problems
Manage nodes
Cluster management with the CLI
- Overview
Cluster and SVM administrators
Access the cluster by using the CLI (cluster administrators only)
Use the ONTAP command-line interface
- Overview
- Different shells for CLI commands (cluster administrators only)
- Methods of navigating CLI command directories
- Rules for specifying values in the CLI
- Methods of viewing command history and reissuing commands
- Keyboard shortcuts for editing CLI commands
- Use of administrative privilege levels
- Set the privilege level in the CLI
- Set display preferences in the CLI
- Methods of using query operators
- Methods of using extended queries
- Methods of customizing show command output by using fields
- About positional parameters
- Methods of accessing ONTAP man pages
Manage CLI sessions (cluster administrators only)
Cluster management (cluster administrators only)
Manage node attributes
Manage nodes
Configure the SP/BMC network
Manage nodes remotely using the SP/BMC
- Overview
- About the Service Processor (SP)
- About the Baseboard Management Controller (BMC)
- Methods of managing SP/BMC firmware updates
- When the SP/BMC uses the network interface for firmware updates
- Accounts that can access the SP
- Access the SP/BMC from an administration host
- Access the SP/BMC from the system console
- Relationship among the SP CLI, SP console, and system console sessions
- Manage the IP addresses that can access the SP
- Use online help at the SP/BMC CLI
- Commands to manage a node remotely
- About the threshold-based SP sensor readings and status values of the system sensors command output
- About the discrete SP sensor status values of the system sensors command output
- Commands for managing the SP from ONTAP
- ONTAP commands for BMC management
- BMC CLI commands
Manage audit logging for management activities
Manage the cluster time (cluster administrators only)
Manage the banner and MOTD
Manage licenses (cluster administrators only)
Manage jobs and schedules
Back up and restore cluster configurations (cluster administrators only)
- What configuration backup files are
- How the node and cluster configurations are backed up automatically
- Commands for managing configuration backup schedules
- Commands for managing configuration backup files
- Find a configuration backup file to use for recovering a node
- Restore the node configuration using a configuration backup file
- Find a configuration to use for recovering a cluster
- Restore a cluster configuration from an existing configuration
- Synchronize a node with the cluster
Manage core dumps (cluster administrators only)
Monitor a storage system
- Overview
- Use AutoSupport and Active IQ Digital Advisor
- When and where AutoSupport messages are sent
- How AutoSupport creates and sends event-triggered messages
- Types of AutoSupport messages and their content
- What AutoSupport subsystems are
- AutoSupport size and time budgets
- Files sent in event-triggered AutoSupport messages
- Log files sent in AutoSupport messages
- Files sent in weekly AutoSupport messages
- How AutoSupport OnDemand obtains delivery instructions from technical support
- Structure of AutoSupport messages sent by email
- AutoSupport severity types
- Requirements for using AutoSupport
- Set up AutoSupport
- Upload core dump files
- Upload performance archive files
- Get AutoSupport message descriptions
- Commands for managing AutoSupport
- Information included in the AutoSupport manifest
- AutoSupport case suppression during scheduled maintenance windows
- Troubleshoot AutoSupport when messages are not received
- Troubleshoot AutoSupport message delivery over HTTP or HTTPS
- Troubleshoot AutoSupport message delivery over SMTP
- Troubleshoot the AutoSupport subsystem
Monitor the health of your system
- Overview
- How health monitoring works
- Ways to respond to system health alerts
- System health alert customization
- How health alerts trigger AutoSupport messages and events
- Available cluster health monitors
- Receive system health alerts automatically
- Respond to degraded system health
- Example of responding to degraded system health
- Configure discovery of cluster and management network switches
- Verify the monitoring of cluster and management network switches
- Commands for monitoring the health of your system
- Display environmental information
Manage web services
- Overview
- Manage access to web services
- Manage the web protocol engine
- Commands for managing the web protocol engine
- Configure SAML authentication for web services
- Configure access to web services
- Commands for managing web services
- Commands for managing mount points on the nodes
- Manage SSL
- Commands for managing SSL
- Troubleshoot web service access problems
Verify the identity of remote servers using certificates
Mutually authenticating the cluster and a KMIP server
Disk and tier (aggregate) management
- Overview
Manage local tiers (aggregates)
- Overview
Prepare to add a local tier (aggregate)
Add (create) a local tier (aggregate)
Manage the use of local tiers (aggregates)
- Overview
- Rename a local tier (aggregate)
- Set media cost of a local tier (aggregate)
- Determine drive and RAID group information for a local tier (aggregate)
- Assign local tiers (aggregates) to storage VMs (SVMs)
- Determine which volumes reside on a local tier (aggregate)
- Determine and control a volume’s space usage in a local tier (aggregate)
- Determine space usage in a local tier (aggregate)
- Relocate local tier (aggregate) ownership within an HA pair
- Delete a local tier (aggregate)
- Commands for relocating local tiers (aggregates)
- Commands for managing local tiers (aggregates)
Add capacity (disks) to a local tier (aggregate)
Manage disks
- Overview
- How hot spare disks work
- How low spare warnings can help you manage your spare disks
- Additional root-data partitioning management options
- When you need to update the Disk Qualification Package
Disk and partition ownership
- Overview
- About auto-assignment of disk ownership
- Display disk and partition ownership
- Change auto-assignment settings for disk ownership
- Manually assign ownership of disks
- Manually assign ownership of partitioned disks
- Set up an active-passive configuration on nodes using root-data partitioning
- Set up an active-passive configuration on nodes using root-data-data partitioning
- Remove ownership from a disk
- Remove a failed disk
Disk sanitization
- Commands for managing disks
- Commands for displaying space usage information
- Commands for displaying information about storage shelves
Manage RAID configurations
Manage Flash Pool local tiers (aggregates)
- Overview
- Flash Pool local tier (aggregate) caching policies
Manage Flash Pool caching policies
- Flash Pool SSD partitioning for Flash Pool local tiers (aggregates) using storage pools
- Flash Pool candidacy and optimal cache size
- Create a Flash Pool local tier (aggregate) using physical SSDs
Create a Flash Pool local tier (aggregate) using SSD storage pools
- Overview
- Determine whether a Flash Pool local tier (aggregate) is using an SSD storage pool
- Add cache by adding an SSD storage pool
- Create a Flash Pool using SSD storage pool allocation units
- Determine the impact to cache size of adding SSDs to an SSD storage pool
- Add SSDs to an SSD storage pool
- Commands for managing SSD storage pools
FabricPool tier management
- Overview
- Benefits of storage tiers by using FabricPool
- Considerations and requirements for using FabricPool
- About FabricPool tiering policies
- FabricPool management workflow
Configure FabricPool
Prepare for FabricPool configuration
- Overview
- Add a connection to the cloud
- Install a FabricPool license
- Install a CA certificate if you use StorageGRID
- Install a CA certificate if you use ONTAP S3
Set up an object store as the cloud tier for FabricPool
- Overview
- Set up StorageGRID as the cloud tier
- Set up ONTAP S3 as the cloud tier
- Set up Alibaba Cloud Object Storage as the cloud tier
- Set up Amazon S3 as the cloud tier
- Set up Google Cloud Storage as the cloud tier
- Set up IBM Cloud Object Storage as the cloud tier
- Set up Azure Blob Storage for the cloud as the cloud tier
- Set up object stores for FabricPool in a MetroCluster configuration
- Test object store throughput performance before attaching to a local tier
- Attach the cloud tier to an aggregate
- Tier data to local bucket
Manage FabricPool
- Overview
- Determine how much data in a volume is inactive by using inactive data reporting
Add or move volumes to FabricPool as needed
Object tagging using user-created custom tags
- Monitor the space utilization for FabricPool
- Manage storage tiering by modifying a volume’s tiering policy or tiering minimum cooling period
- Archive volumes with FabricPool (video)
- Use cloud migration controls to override a volume’s default tiering policy
Promote data to the performance tier
Manage FabricPool mirrors
- Commands for managing aggregates with FabricPool
SVM data mobility
HA pair management
- Overview
- How hardware-assisted takeover works
- How automatic takeover and giveback works
- Automatic takeover commands
- Automatic giveback commands
- Manual takeover commands
- Manual giveback commands
- Testing takeover and giveback
- Commands for monitoring an HA pair
- Commands for enabling and disabling storage failover
- Halt or reboot a node without initiating takeover
Rest API management with System Manager
Volume administration
Volume and LUN management with System Manager
- Overview
- Manage volumes
- Add a volume
- Add LUNs
- Expand volumes and LUNs
- Recover deleted volumes
- Save storage space
- Balance load by moving LUNs
- Balance loads by moving volumes to another tier
- Use Ansible Playbooks to add or edit volumes or LUNs
- Manage storage efficiency policies
- Manage resources using quotas
- Limit resource use
- Clone data with FlexClone
- Search, filter, and sort
- Capacity measurements
Logical storage management with the CLI
- Overview
Create and manage volumes
- Create a volume
- Enable large volume and large file support
SAN volumes
- About
- Configure volume provisioning options
- Determine space usage in a volume or aggregate
- Delete Snapshot copies automatically
- Configure volumes to automatically provide more space when they are full
- Configure volumes to automatically grow and shrink their size
- Requirements for enabling both autoshrink and automatic Snapshot copy deletion
- How the autoshrink functionality interacts with Snapshot copy deletion
- Address FlexVol volume fullness and overallocation alerts
- Address aggregate fullness and overallocation alerts
- Considerations for setting fractional reserve
- Display file or inode usage
- Control and monitoring I/O performance to FlexVol volumes by using Storage QoS
- Delete a FlexVol volume
- Protection against accidental volume deletion
Delete directories
- Commands for managing FlexVol volumes
Move and copy volumes
Use FlexClone volumes to create efficient copies of your FlexVol volumes
Use FlexClone files and FlexClone LUNs to create efficient copies of files and LUNs
- Overview
- Create a FlexClone file or FlexClone LUN
- View node capacity for creating and deleting FlexClone files and FlexClone LUNs
- View the space savings due to FlexClone files and FlexClone LUNs
- Methods to delete FlexClone files and FlexClone LUNs
How a FlexVol volume can reclaim free space with autodelete setting
Use qtrees to partition your FlexVol volumes
Logical space reporting and enforcement for volumes
Use quotas to restrict or track resource usage
Overview of the quota process
- Quota process
- Differences among hard, soft, and threshold quotas
- About quota notifications
- Why you use quotas
- What quota rules, quota policies, and quotas are
- Quota targets and types
Special kinds of quotas
- How quotas are applied
- Considerations for assigning quota policies
How quotas work with users and groups
- Overview
- How you specify UNIX users for quotas
- How you specify Windows users for quotas
- How default user and group quotas create derived quotas
- How quotas are applied to the root user
- How quotas work with special Windows groups
- How quotas are applied to users with multiple IDs
- How ONTAP determines user IDs in a mixed environment
- How quotas with multiple users work
- How you link UNIX and Windows names for quotas
- How quotas work with qtrees
How tree quotas work
How qtree changes affect quotas
How quotas are activated
How you can view quota information
- Overview
- How you can use the quota report to see what quotas are in effect
- Why enforced quotas differ from configured quotas
- Use the quota report to determine which quotas limit writes to a specific file
- Commands for displaying information about quotas
- When to use the volume quota policy rule show and volume quota report commands
Difference in space usage displayed by a quota report and a UNIX client
- Examples of quota configuration
- Set up quotas on an SVM
- Modify (or Resizing) quota limits
- Reinitialize quotas after making extensive changes
- Commands to manage quota rules and quota policies
- Commands to activate and modify quotas
Use deduplication, data compression, and data compaction to increase storage efficiency
- Overview
- Enable deduplication on a volume
- Disable deduplication on a volume
- Manage automatic volume-level background deduplication on AFF systems
- Manage aggregate-level inline deduplication on AFF systems
- Manage aggregate-level background deduplication on AFF systems
- Temperature-sensitive storage efficiency overview
- Storage efficiency behavior with volume move and SnapMirror
- Set storage efficiency modes
- Change volume inactive data compression threshold
- Check volume efficiency mode
- Change volume efficiency mode
- View volume footprint savings with or without temperature-sensitive storage efficiency
- Enable data compression on a volume
- Move between secondary compression and adaptive compression
- Disable data compression on a volume
- Manage inline data compaction for AFF systems
- Enable inline data compaction for FAS systems
- Inline storage efficiency enabled by default on AFF systems
- Enable storage efficiency visualization
Create a volume efficiency policy to run efficiency operations
Manage volume efficiency operations manually
Manage volume efficiency operations using schedules
Monitor volume efficiency operations
- Stop volume efficiency operations
- Information about removing space savings from a volume
Rehost a volume from one SVM to another SVM
- Storage limits
Recommended volume and file or LUN configuration combinations
- Overview
- Determine the correct volume and LUN configuration combination for your environment
- Configuration settings for space-reserved files or LUNs with thick-provisioned volumes
- Configuration settings for non-space-reserved files or LUNs with thin-provisioned volumes
- Configuration settings for space-reserved files or LUNs with semi-thick volume provisioning
Cautions and considerations for changing file or directory capacity
Features supported with FlexClone files and FlexClone LUNs
- Overview
- How deduplication works with FlexClone files and FlexClone LUNs
- How Snapshot copies work with FlexClone files and FlexClone LUNs
- How access control lists work with FlexClone files and FlexClone LUNs
- How quotas work with FlexClone files and FlexClone LUNs
- How FlexClone volumes work with FlexClone files and FlexClone LUNs
- How NDMP works with FlexClone files and FlexClone LUNs
- How volume SnapMirror works with FlexClone files and FlexClone LUNs
- How volume move affects FlexClone files and FlexClone LUNs
- How space reservation works with FlexClone files and FlexClone LUNs
- How an HA configuration works with FlexClone files and FlexClone LUNs
- Provision NAS storage for large file systems using FlexGroup volumes
FlexGroup volumes management with the CLI
- Overview
- What a FlexGroup volume is
- Supported and unsupported configurations for FlexGroup volumes
FlexGroup volume setup
Manage FlexGroup volumes
- Monitor the space usage of a FlexGroup volume
- Increase the size of a FlexGroup volume
- Reduce the size of a FlexGroup volume
- Configure FlexGroup volumes to automatically grow and shrink their size
- Delete directories rapidly on a cluster
- Manage client rights to delete directories rapidly
- Create qtrees with FlexGroup volumes
- Use quotas for FlexGroup volumes
- Enable storage efficiency on a FlexGroup volume
- Protect FlexGroup volumes using Snapshot copies
- Move the constituents of a FlexGroup volume
- Use aggregates in FabricPool for existing FlexGroup volumes
- Rebalance FlexGroup volumes
Data protection for FlexGroup volumes
- Workflow
- Create a SnapMirror relationship for FlexGroup volumes
- Create a SnapVault relationship for FlexGroup volumes
- Create a unified data protection relationship for FlexGroup volumes
- Create an SVM disaster recovery relationship for FlexGroup volumes
- Transition an existing FlexGroup SnapMirror relationship to SVM DR
- Convert a FlexVol volume to a FlexGroup volume within an SVM-DR relationship
- Considerations for creating SnapMirror cascade and fanout relationships for FlexGroups
- Considerations for creating a SnapVault backup relationship and a unified data protection relationship for FlexGroup volumes
- Monitor SnapMirror data transfers for FlexGroup volumes
Manage data protection operations for FlexGroup volumes
Convert FlexVol volumes to FlexGroup volumes
- Improve performance for multiple clients with FlexCache
FlexCache volumes management with the CLI
Network management
Manage your network with System Manager
Set up NAS path failover with the CLI
Manage your network with the CLI
- Network management overview
Upgrade considerations
Networking components of a cluster
Configure network ports (cluster administrators only)
- Overview
- Combine physical ports to create interface groups
- Configure VLANs over physical ports
- Modify network port attributes
- Modify MTU setting for interface group ports
- Monitor the health of network ports
- Monitor the reachability of network ports in ONTAP 9.8 and later
- Convert 40GbE NIC ports into multiple 10GbE ports for 10GbE connectivity
- Removing a NIC from the node on ONTAP 9.7 or earlier
- Removing a NIC from the node on ONTAP 9.8 or later
Configure IPspaces (cluster administrators only)
Configure broadcast domains (cluster administrators only)
ONTAP 9.8 and later
- About broadcast domains for ONTAP 9.8 and later
- Example of using broadcast domains
- Add a broadcast domain
- Add or remove ports from a broadcast domain
- Split broadcast domains
- Merge broadcast domains
- Change the MTU value for ports in a broadcast domain
- Display broadcast domains
- Delete a broadcast domain
ONTAP 9.7 and earlier
- About broadcast domains for ONTAP 9.7 and earlier
- Create a broadcast domain
Configure failover groups and policies for LIFs
Configure subnets (cluster administrators only)
Configure LIFs (cluster administrators only)
- Overview
- LIF compatibility with port types
- LIF roles in ONTAP 9.5 and earlier
- LIFs and service policies
- Configure LIF service policies
- Create a LIF
- Modify a LIF
- Migrate a LIF
- Revert a LIF to its home port
- ONTAP 9.8 or later-Recover from an incorrectly configured cluster LIF
- Delete a LIF
- Configure virtual IP (VIP) LIFs
Configure host-name resolution
Balance network loads to optimize user traffic (cluster administrators only)
Secure your network
Configure QoS marking (cluster administrators only)
Manage SNMP on the cluster (cluster administrators only)
Manage routing in an SVM
ONTAP port usage on a storage system
View network information
- Overview
- Display network port information
- Display information about a VLAN (cluster administrators only)
- Display interface group information (cluster administrators only)
- Display LIF information
- Display routing information
- Display DNS host table entries (cluster administrators only)
- Display DNS domain configurations
- Display information about failover groups
- Display LIF failover targets
- Display LIFs in a load balancing zone
- Display cluster connections
- Commands for diagnosing network problems
- Display network connectivity with neighbor discovery protocols
NAS storage management
Manage NAS protocols with System Manager
- NAS storage overview
- VMware datastores
- Home directories
- Linux servers
- Export policies
- Windows servers
- Both Windows and Linux
- Secure client access with Kerberos
- Provide client access with name services
- Manage directories and files
- Manage host-specific users and groups
- Monitor NFS active clients
Enable NAS storage
Configure NFS with the CLI
- Overview
- Workflow
Preparation
Configure NFS access to an SVM
- Create an SVM
- Verify that the NFS protocol is enabled on the SVM
- Open the export policy of the SVM root volume
- Create an NFS server
- Create a LIF
- Enable DNS for host-name resolution
Configure name services
Use Kerberos with NFS for strong security
Add storage capacity to an NFS-enabled SVM
- Where to find additional information
How ONTAP exports differ from 7-Mode exports
Manage NFS with the CLI
- Overview
Understand NAS file access
Create and manage data volumes in NAS namespaces
Configure security styles
Set up file access using NFS
- Overview
Secure NFS access using export policies
- How export policies control client access to volumes or qtrees
- Default export policy for SVMs
- How export rules work
- Manage clients with an unlisted security type
- How security types determine client access levels
- Manage superuser access requests
- How ONTAP uses export policy caches
- How the access cache works
- How access cache parameters work
- Removing an export policy from a qtree
- Validating qtree IDs for qtree file operations
- Export policy restrictions and nested junctions for FlexVol volumes
Using Kerberos with NFS for strong security
Configure name mappings
- Enable access for Windows NFS clients
- Enable the display of NFS exports on NFS clients
Manage file access using NFS
- Enable or disable NFSv3
- Enable or disable NFSv4.0
- Enable or disable NFSv4.1
- Manage NFSv4 storepool limits
- Enable or disable pNFS
- Controlling NFS access over TCP and UDP
- Controlling NFS requests from nonreserved ports
- Handling NFS access to NTFS volumes or qtrees for unknown UNIX users
- Considerations for clients that mount NFS exports using a nonreserved port
- Performing stricter access checking for netgroups by verifying domains
- Modifying ports used for NFSv3 services
- Commands for managing NFS servers
- Troubleshooting name service issues
- Verifying name service connections
- Commands for managing name service switch entries
- Commands for managing name service cache
- Commands for managing name mappings
- Commands for managing local UNIX users
- Commands for managing local UNIX groups
- Limits for local UNIX users, groups, and group members
- Manage limits for local UNIX users and groups
- Commands for managing local netgroups
- Commands for managing NIS domain configurations
- Commands for managing LDAP client configurations
- Commands for managing LDAP configurations
- Commands for managing LDAP client schema templates
- Commands for managing NFS Kerberos interface configurations
- Commands for managing NFS Kerberos realm configurations
- Commands for managing export policies
- Commands for managing export rules
Configure the NFS credential cache
Manage export policy caches
Manage file locks
- How FPolicy first-read and first-write filters work with NFS
- Modifying the NFSv4.1 server implementation ID
Manage NFSv4 ACLs
Manage NFSv4 file delegations
Configure NFSv4 file and record locking
- How NFSv4 referrals work
- Enable or disable NFSv4 referrals
- Displaying NFS statistics
- Displaying DNS statistics
- Displaying NIS statistics
- Support for VMware vStorage over NFS
- Enable or disable VMware vStorage over NFS
- Enable or disable rquota support
- NFSv3 and NFSv4 performance improvement by modifying the TCP transfer size
- Modifying the NFSv3 and NFSv4 TCP maximum transfer size
- Configure the number of group IDs allowed for NFS users
- Controlling root user access to NTFS security-style data
Supported NFS versions and clients
NFS and SMB file and directory naming dependencies
- Overview
- Characters a file or directory name can use
- Case-sensitivity of file and directory names in a multiprotocol environment
- How ONTAP creates file and directory names
- How ONTAP handles multi-byte file, directory, and qtree names
- Configure character mapping for SMB file name translation on volumes
- Commands for managing character mappings for SMB file name translation
Manage NFS over RDMA
Configure SMB with the CLI
- Overview
- Workflow
Preparation
Configure SMB access to an SVM
- Overview
- Create an SVM
- Verify that the SMB protocol is enabled on the SVM
- Create a LIF
Set up an SMB server in an Active Directory domain
Set up an SMB server in a workgroup
- Verify enabled SMB versions
- Map the SMB server on the DNS server
Configure SMB client access to shared storage
Manage SMB with the CLI
- Overview
SMB server support
Manage SMB servers
- Modify SMB servers
Use options to customize SMB servers
Manage SMB server security settings
- How ONTAP handles SMB client authentication
- Guidelines for SMB server security settings in an SVM disaster recovery configuration
- Display information about CIFS server security settings
- Enable or disable required password complexity for local SMB users
- Modify the CIFS server Kerberos security settings
- Set the CIFS server minimum authentication security level
- Configure strong security for Kerberos-based communication by using AES encryption
- Enable or disable AES encryption for Kerberos-based communication
Use SMB signing to enhance network security
- Overview
- How SMB signing policies affect communication with a CIFS server
- Performance impact of SMB signing
- Recommendations for configuring SMB signing
- Guidelines for SMB signing when multiple data LIFS are configured
- Enable or disable required SMB signing for incoming SMB traffic
- Determining whether SMB sessions are signed
- Monitor SMB signed session statistics
Configure required SMB encryption on SMB servers for data transfers over SMB
Secure LDAP session communication
- Configure SMB Multichannel for performance and redundancy
Configure default Windows user to UNIX user mappings on the SMB server
- Display information about what types of users are connected over SMB sessions
- Command options to limit excessive Windows client resource consumption
Improve client performance with traditional and lease oplocks
Apply Group Policy Objects to SMB servers
- Overview
- Supported GPOs
- Requirements for using GPOs with your CIFS server
- Enable or disable GPO support on a SMB server
How GPOs are updated on the SMB server
- Manually updating GPO settings on the CIFS server
- Display information about GPO configurations
- Display detailed information about restricted group GPOs
- Display information about central access policies
- Display information about central access policy rules
- Commands for managing CIFS servers computer account passwords
Manage domain controller connections
Use null sessions to access storage in non-Kerberos environments
Manage NetBIOS aliases for SMB servers
Manage miscellaneous SMB server tasks
Use IPv6 for SMB access and SMB services
Set up file access using SMB
Configure multidomain name-mapping searches
Create and configure SMB shares
- Overview
- What the default administrative shares are
- SMB share naming requirements
- Directory case-sensitivity requirements when creating shares in a multiprotocol environment
Use SMB share properties
- Optimize SMB user access with the force-group share setting
- Create an SMB share with the force-group share setting
- View information about SMB shares using the MMC
- Commands for managing SMB shares
Secure file access by using SMB share ACLs
Secure file access by using file permissions
Secure file access by using Dynamic Access Control (DAC)
- Overview
- Supported Dynamic Access Control functionality
- Considerations when using Dynamic Access Control and central access policies with CIFS servers
- Enable or disable Dynamic Access Control
- Manage ACLs that contain Dynamic Access Control ACEs when Dynamic Access Control is disabled
- Configure central access policies to secure data on CIFS servers
- Display information about Dynamic Access Control security
- Revert considerations for Dynamic Access Control
- Where to find additional information about configuring and using Dynamic Access Control and central access policies
Secure SMB access using export policies
Secure file access by using Storage-Level Access Guard
Manage file access using SMB
Use local users and groups for authentication and authorization
How ONTAP uses local users and groups
- Local users and groups concepts
- Reasons for creating local users and local groups
- How local user authentication works
- How user access tokens are constructed
- Guidelines for using SnapMirror on SVMs that contain local groups
- What happens to local users and groups when deleting CIFS servers
- How you can use Microsoft Management Console with local users and groups
- Guidelines for reverting
What local privileges are
- Guidelines for using BUILTIN groups and the local administrator account
- Requirements for local user passwords
- Predefined BUILTIN groups and default privileges
Enable or disable local users and groups functionality
Manage local user accounts
Manage local groups
Manage local privileges
Configure bypass traverse checking
Display information about file security and audit policies
- Overview
- Display information about file security on NTFS security-style volumes
- Display information about file security on mixed security-style volumes
- Display information about file security on UNIX security-style volumes
- Display information about NTFS audit policies on FlexVol volumes using the CLI
- Display information about NFSv4 audit policies on FlexVol volumes using the CLI
- Ways to display information about file security and audit policies
Manage NTFS file security, NTFS audit policies, and Storage-Level Access Guard on SVMs using the CLI
- Overview
- Use cases for using the CLI to set file and folder security
- Limits when using the CLI to set file and folder security
- How security descriptors are used to apply file and folder security
- Guidelines for applying file-directory policies that use local users or groups on the SVM disaster recovery destination
Configure and apply file security on NTFS files and folders using the CLI
Configure and apply audit policies to NTFS files and folders using the CLI
- Considerations when managing security policy jobs
- Commands for managing NTFS security descriptors
- Commands for managing NTFS DACL access control entries
- Commands for managing NTFS SACL access control entries
- Commands for managing security policies
- Commands for managing security policy tasks
- Commands for managing security policy jobs
Configure the metadata cache for SMB shares
Manage file locks
Monitor SMB activity
Deploy SMB client-based services
Use offline files to allow caching of files for offline use
Use roaming profiles to store user profiles centrally on a SMB server associated with the SVM
Use folder redirection to store data on a SMB server
- Access the ~snapshot directory from Windows clients using SMB 2.x
Recover files and folders using Previous Versions
- Overview
- Requirements for using Microsoft Previous Versions
- Use the Previous Versions tab to view and manage Snapshot copy data
- Determine whether Snapshot copies are available for Previous Versions use
- Create a Snapshot configuration to enable Previous Versions access
- Guidelines for restoring directories that contain junctions
Deploy SMB server-based services
Manage home directories
- How ONTAP enables dynamic home directories
Home directory shares
- Add a home directory search path
- Create a home directory configuration using the %w and %d variables
- Configure home directories using the %u variable
- Additional home directory configurations
- Commands for managing search paths
- Display information about an SMB user’s home directory path
- Manage accessibility to users' home directories
Configure SMB client access to UNIX symbolic links
- How ONTAP enables you to provide SMB client access to UNIX symbolic links
- Limits when configuring UNIX symbolic links for SMB access
- Control automatic DFS advertisements in ONTAP with a CIFS server option
- Configure UNIX symbolic link support on SMB shares
- Create symbolic link mappings for SMB shares
- Commands for managing symbolic link mappings
Use BranchCache to cache SMB share content at a branch office
- Overview
Requirements and guidelines
Configure BranchCache
Configure BranchCache-enabled SMB shares
Manage and monitor the BranchCache configuration
- Modify BranchCache configurations
- Display information about BranchCache configurations
- Change the BranchCache server key
- Pre-computing BranchCache hashes on specified paths
- Flush hashes from the SVM BranchCache hash store
- Display BranchCache statistics
- Support for BranchCache Group Policy Objects
- Display information about BranchCache Group Policy Objects
Disable BranchCache on SMB shares
Disable or enable BranchCache on the SVM
Delete the BranchCache configuration on SVMs
- What happens to BranchCache when reverting
Improve Microsoft remote copy performance
Improve client response time by providing SMB automatic node referrals with Auto Location
- Overview
- Requirements and guidelines for using automatic node referrals
- Support for SMB automatic node referrals
- Enable or disable SMB automatic node referrals
- Use statistics to monitor automatic node referral activity
- Monitor client-side SMB automatic node referral information using a Windows client
Provide folder security on shares with access-based enumeration
- Overview
Provide S3 client access to NAS data
SMB configuration for Microsoft Hyper-V and SQL Server
- Overview
- Configure ONTAP for Microsoft Hyper-V and SQL Server over SMB solutions
Nondisruptive operations for Hyper-V and SQL Server over SMB
- What are nondisruptive operations?
- Protocols that enable nondisruptive operations over SMB
- Key concepts about nondisruptive operations for Hyper-V and SQL Server over SMB
- How SMB 3.0 functionality supports nondisruptive operations over SMB shares
- What the Witness protocol does to enhance transparent failover
- How the Witness protocol works
Share-based backups with Remote VSS
- How ODX copy offload is used with Hyper-V and SQL Server over SMB shares
Configuration requirements and considerations
- ONTAP and licensing requirements
- Network and data LIF requirements
- SMB server and volume requirements for Hyper-V over SMB
- SMB server and volume requirements for SQL Server over SMB
- Continuously available share requirements and considerations for Hyper-V over SMB
- Continuously available share requirements and considerations for SQL Server over SMB
- Remote VSS considerations for Hyper-V over SMB configurations
- ODX copy offload requirements for SQL Server and Hyper-V over SMB
- Recommendations for SQL Server and Hyper-V over SMB configurations
Plan the Hyper-V or SQL Server over SMB configuration
Create ONTAP configurations for nondisruptive operations with Hyper-V and SQL Server over SMB
- Overview
- Verify that both Kerberos and NTLMv2 authentication are permitted (Hyper-V over SMB shares)
- Verify that domain accounts map to the default UNIX user
- Verify that the security style of the SVM root volume is set to NTFS
- Verify that required CIFS server options are configured
- Create NTFS data volumes
- Create continuously available SMB shares
- Add the SeSecurityPrivilege privilege to the user account (for SQL Server of SMB shares)
- Configure the VSS shadow copy directory depth (for Hyper-V over SMB shares)
Manage Hyper-V and SQL Server over SMB configurations
Use statistics to monitor Hyper-V and SQL Server over SMB activity
Verify that the configuration is capable of nondisruptive operations
SAN storage management
SAN concepts
- SAN provisioning with iSCSI
iSCSI service management
- SAN provisioning with FC
- SAN provisioning with NVMe
About SAN volumes
About host-side space management
- About igroups
- Example of how igroups give LUN access
- Specify initiator WWPNs and iSCSI node names for an igroup
Storage virtualization with VMware and Microsoft copy offload
SAN administration
SAN provisioning
NVMe provisioning
Manage LUNs
- Edit LUN QoS Policy
- Convert a LUN into a namespace
- Take a LUN offline
- Resize a LUN
- Move a LUN
- Delete a LUN
- What to know before copying LUNs
- Examine configured and used space of a LUN
- Control and monitor I/O performance to LUNs using Storage QoS
- Tools available to effectively monitor your LUNs
- Capabilities and restrictions of transitioned LUNs
- I/O misalignments on properly aligned LUNs
- Ways to address issues when LUNs go offline
- Troubleshoot iSCSI LUNs not visible on the host
Manage igroups and portsets
Manage iSCSI protocol
- Configure your network for best performance
- Configure an SVM for iSCSI
- Define a security policy method for an initiator
- Delete an iSCSI service for an SVM
- Get more details in iSCSI session error recoveries
- Register the SVM with an iSNS server
- Resolve iSCSI error messages on the storage system
- iSCSI LIF failover for ASA platforms
Manage FC protocol
Manage NVMe protocol
Manage systems with FC adapters
- Overview
- Commands for managing FC adapters
- Configure FC adapters
- View adapter settings
- Change the UTA2 port from CNA mode to FC mode
- Change the CNA/UTA2 target adapter optical modules
- Supported port configurations for X1143A-R6 adapters
- Configure X1143A-R6 adapter ports
- Prevent loss of connectivity when using the X1133A-R6 adapter
Manage LIFs for all SAN protocols
- Overview
- Calculate rate of data growth for LUNs
SAN data protection
- Overview
Effect of moving or copying a LUN on Snapshot copies
Use FlexClone LUNs to protect your data
- Overview
- Reasons for using FlexClone LUNs
- How a FlexVol volume can reclaim free space with autodelete setting
- Configure a FlexVol volume to automatically delete FlexClone files and FlexClone LUNs
- Clone LUNs from an active volume
- Create FlexClone LUNs from a Snapshot copy in a volume
- Prevent a specific FlexClone file or FlexClone LUN from being automatically deleted
Configure and use SnapVault backups in a SAN environment
- How you can connect a host backup system to the primary storage system
- Back up a LUN through a host backup system
SAN configuration reference
- Overview
Considerations for iSCSI configurations
- Considerations for FC-NVMe configurations
Considerations for FC configurations
Manage X1143A-R6 adapters
Ways to Configure FCoE
Fibre Channel and FCoE zoning
- Requirements for shared SAN configurations
Host support for multipathing
Configuration limits
Considerations for SAN configurations in a MetroCluster environment
S3 object storage management
S3 configuration
- Overview
S3 support in ONTAP 9
About the S3 configuration process
Configure S3 access to an SVM
Add storage capacity to an S3-enabled SVM
- Storage service definitions
Protect buckets with S3 SnapMirror
Audit S3 events
Security and data encryption
- Security with System Manager
Manage administrator authentication and RBAC
- Overview
- Workflow
- Configuration worksheets
Create login accounts
Manage access-control roles
