Commands for managing job schedules
Many tasks—​for instance, volume Snapshot copies—​can be configured to run on specified schedules.Schedules that run at specific times are called cron schedules (similar to UNIX cron schedules). Schedules that run at intervals are called interval schedules. You use the job schedule commands to manage job schedules.
Job schedules do not adjust to manual changes to the cluster date and time. These jobs are scheduled to run based on the current cluster time when the job was created or when the job most recently ran. Therefore, if you manually change the cluster date or time, you should use the job show and job history show commands to verify that all scheduled jobs are queued and completed according to your requirements.
If the cluster is part of a MetroCluster configuration, then the job schedules on both clusters must be identical. Therefore, if you create, modify, or delete a job schedule, you must perform the same operation on the remote cluster.
If you want to…​ Use this command…​
Display information about all schedules
job schedule show
Display the list of jobs by schedule
job schedule show-jobs
Display information about cron schedules
job schedule cron show
Display information about interval schedules
job schedule interval show
Create a cron schedule1
job schedule cron create
Create an interval schedule
job schedule interval create
You must specify at least one of the following parameters: -days, -hours, -minutes, or -seconds.
Modify a cron schedule
job schedule cron modify
Modify an interval schedule
job schedule interval modify
Delete a schedule
job schedule delete
Delete a cron schedule
job schedule cron delete
Delete an interval schedule
job schedule interval delete
1Beginning with ONTAP 9.10.1, when you create a job schedule by using the job schedule cron create command, you can include the Vserver for your job schedule.
Related information
