Commands for managing mount points on ONTAP nodes
The spi web service automatically creates a mount point from one node to another node's root volume upon a request to access the node's log files or core files. Although you do not need to manually manage mount points, you can do so by using the system node root-mount commands.
| If you want to… | Use this command… |
Manually create a mount point from one node to another node's root volume |
Display existing mount points on the nodes in the cluster, including the time a mount point was created and its current state |
Delete a mount point from one node to another node's root volume and force connections to the mount point to close |
Related information
