Commands for managing the cluster time
You use the cluster time-service ntp server commands to manage the NTP servers for the cluster. You use the cluster date commands to manage the cluster time manually.
Beginning in ONTAP 9.5, you can configure your NTP server with symmetric authentication.
The following commands enable you to manage the NTP servers for the cluster:
If you want to…​ Use this command…​
Associate the cluster with an external NTP server without symmetric authentication
cluster time-service ntp server create -server server_name
Associate the cluster with an external NTP server with symmetric authenticationAvailable in ONTAP 9.5 or later
cluster time-service ntp server create -server server_ip_address -key-id key_id
Note
The key_id must refer to an existing shared key configured with '`cluster time-service ntp key'.
Enable symmetric authentication for an existing NTP serverAn existing NTP server can be modified to enable authentication by adding the required key-id.
cluster time-service ntp server modify -server server_name -key-id key_id
Disable symmetric authentication
cluster time-service ntp server modify -server server_name -authentication disabled
Configure a shared NTP key
cluster time-service ntp key create -id shared_key_id -type shared_key_type -value shared_key_value
Note
Shared keys are referred to by an ID. The ID, its type, and value must be identical on both the node and the NTP server
Display information about the NTP servers that are associated with the cluster
cluster time-service ntp server show
Modify the configuration of an external NTP server that is associated with the cluster
Dissociate an NTP server from the cluster
cluster time-service ntp server delete
Reset the configuration by clearing all external NTP servers' association with the cluster
cluster time-service ntp server reset
Note
This command requires the advanced privilege level.
The following commands enable you to manage the cluster time manually:
Set or modify the time zone, date, and time
cluster date modify
Display the time zone, date, and time settings for the cluster
cluster date show
Related information
