Troubleshoot AutoSupport when messages are not received
PDF of this doc site
Cluster administration
Volume administration
Logical storage management with the CLI
NAS storage management
Configure NFS with the CLI
Manage NFS with the CLI
Manage SMB with the CLI
Manage file access using SMB
Security and data encryption
Data protection and disaster recovery
Creating your file...
If the system does not send the AutoSupport message, you can determine whether that is because AutoSupport cannot generate the message or cannot deliver the message.
Check delivery status of the messages by using the
system node autosupport history show
command. -
Read the status.
This status Means initializing
The collection process is starting. If this state is temporary, all is well. However, if this state persists, there is an issue.
collection-failed
AutoSupport cannot create the AutoSupport content in the spool directory. You can view what AutoSupport is trying to collect by entering the
system node autosupport history show -detail
command.collection-in-progress
AutoSupport is collecting AutoSupport content. You can view what AutoSupport is collecting by entering the
system node autosupport manifest show
command.queued
AutoSupport messages are queued for delivery, but not yet delivered.
transmitting
AutoSupport is currently delivering messages.
sent-successful
AutoSupport successfully delivered the message. You can find out where AutoSupport delivered the message by entering the
system node autosupport history show -delivery
command.ignore
AutoSupport has no destinations for the message. You can view the delivery details by entering the
command.re-queued
AutoSupport tried to deliver messages, but the attempt failed. As a result, AutoSupport placed the messages back in the delivery queue for another attempt. You can view the error by entering the
command.transmission-failed
AutoSupport failed to deliver the message the specified number of times and stopped trying to deliver the message. You can view the error by entering the
command.ondemand-ignore
The AutoSupport message was processed successfully, but the AutoSupport OnDemand service chose to ignore it.
Perform one of the following actions:
For this status Do this initializing or collection-failed
Contact NetApp Support, because AutoSupport cannot generate the message. Mention the following Knowledge Base article:
ignore, re-queued, or transmission failed
Check that destinations are correctly configured for SMTP, HTTP, or HTTPS because AutoSupport cannot deliver the message.
