NetApp SMI-S Provider
Deployment workflow
Contributors Noah-Hardy
Before you can manage and monitor your storage systems using SMI-S Provider, you must install the SMI-S Provider software and validate your preliminary configuration.
A diagram that shows SMI-S Provider deployment, preconfiguration validation, and management task workflows
