NetApp SMI-S Provider
Logging levels
You can specify the types of messages that are logged (for example, you want only fatal system messages to be logged).
You can configure the logging level to one of the following:
  • TRACE
    Saves trace messages in the cimserver_standard log.
  • INFORMATION
    Logs all (informational, warning, severe, and fatal) system messages.
  • WARNING
    Logs warning, severe, and fatal system messages.
  • SEVERE
    Logs severe and fatal system messages
  • FATAL
    Logs only fatal system messages.
