NetApp SMI-S Provider
Filer return: No ontap element in response
Contributors netapp-maireadn
The Filer return: No ontap element in response message occurs when an ONTAP API call made by NetApp SMI-S Provider times out. Increase the timeout value to resolve this issue.
  • Message
    Filer return: No ontap element in response.
  • Description
    This message occurs when the ONTAP API call times out. The default ONTAP API call timeout is 60 seconds, which might be too short in some scenarios.
  • Corrective action
    Change the ONTAP API call timeout to a value greater than 60 seconds by setting the environment variable ONTAPI_TIMEOUT_SEC, and then restart SMI-S Provider.
