NetApp SMI-S Provider
NetApp SMI-S Provider components
Contributors netapp-pcarriga netapp-maireadn
NetApp SMI-S Provider consists of three components that enable you to manage and monitor storage systems: CIMOM, provider objects, and a repository.
  • CIMOM
    This is the foundation for NetApp SMI-S Provider. CIMOM collects, validates, and authenticates each application request and then responds to the application. It becomes a conduit for each request by invoking the appropriate provider to handle each request.
  • Provider objects
    When a host issues a command or query to SMI-S Provider, CIMOM loads a shared library object, invokes it to handle a request, and returns the resulting information to the host.
    Note
    Windows hosts use DLL objects.
  • Repository
    CIMOM uses a flat-file database for its repository. It stores persistent data required at the CIM level.
