slptool
You can use the slptool command to display information about WBEM services.
Syntax
slptool [options] subcommand
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
Administrator (Windows)
Options
-i
Specifies one or more interfaces.
-l
Specifies a language tag.
-s
Specifies a list of scopes (separated by commas).
-u
Specifies one interface.
-v
Displays the version of
slptooland OpenSLP.
