NetApp SMI-S Provider support for ONTAP systems
NetApp SMI-S Provider supports cluster platforms that run ONTAP 9 and later.
For NetApp SMI-S Provider to create clones of storage volumes (LUNs), you must have installed a FlexClone license on the storage system.
NetApp SMI-S Provider supports FAS systems.
NetApp SMI-S Provider does not support ASA systems.
