smis config show
The smis config show command lists the current CIM server configuration information.
Syntax
smis config show
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
Administrator (Windows)
Example
The smis config show and its output:
smis config show slp: Current value: true tracelevel: Current value: 4 traceComponents: Current value: XmlIO,Thread, IndicationGeneration, DiscardedData, CMPIProvider, LogMessages, ProviderManager, SSL, Authentication, Authorization traceFilePath: Current value: traces/cimserver.trc enableAuditLog: Current value: true logLevel: Current value: WARNING sslKeyFilePath: Current value: cimom.key sslCertificateFilePath: Current value: cimom.cert passwordFilePath: Current value: cimserver.passwd enableHttpConnection: Current value: true enableHttpsConnection: Current value: true httpPort: Current value: 5988 httpsPort: Current value: 5989 enableAuthentication: Current value: true
