smis crsp
The smis crsp command describes CIM-registered subprofiles supported by NetApp SMI-S Provider, including NetApp SMI-S Provider subprofiles.
Syntax
smis crsp
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis crsp command and its abbreviated output:
smis crsp PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Object Manager Adapter:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Software:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Multiple Computer System:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Access Points:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Target Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Health:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Storage:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File System Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Filesystem Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Server Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem Quotas:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Location:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:NAS Network Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Capacity Utilization:1.4.0"
