smis delete
The smis delete command deletes a storage system.
Syntax
smis delete
storage_sys
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
Administrator (Windows)
storage_sysName or the IP address of the storage system that you are adding
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
Delete a storage system labeled mgt-1:
smis delete mgt-1
If no error message appears, the storage system was successfully deleted.
