smis disks
The smis disks command displays disk information for storage systems. The smis disks command is only supported on ONTAP 7-Mode controllers.
Syntax
smis disks
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis disks command and its abbreviated output:
smis disks ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.3",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.5",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.7",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.6",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.1",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" ONTAP_DiskExtent.CreationClassName="ONTAP_DiskExtent",DeviceID="0c.00.8",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815"
