smis initiators
The smis initiators command displays Fibre Channel and iSCSI port information for storage systems.
Syntax
smis initiators
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis initiators command and its abbreviated output:
smis initiators ONTAP_StorageHardwareID.InstanceID="ONTAP:0084259609:iqn.1991-05.com.microsoft:sf-tpc1" ONTAP_StorageHardwareID.InstanceID="ONTAP:0084259609:21:00:00:e0:8b:86:f2:89" ONTAP_StorageHardwareID.InstanceID="ONTAP:0084259609:iqn.1991-05.com.microsoft:went2k3x32-01"
