smis licensed
The smis licensed command lists the licensed features for storage systems.
Syntax
smis licensed
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis licensed command and its abbreviated output:
smis licensed ONTAP_SoftwareIdentity.InstanceID="ONTAP:0084259609:cifs" ONTAP_SoftwareIdentity.InstanceID="ONTAP:0084259609:cluster" ONTAP_SoftwareIdentity.InstanceID="ONTAP:0084259609:fcp" ONTAP_SoftwareIdentity.InstanceID="ONTAP:0084259609:iscsi" ONTAP_SoftwareIdentity.InstanceID="ONTAP:0084259609:nfs"
