smis namespaces
The smis namespaces command lists the registered namespaces for the CIMOM.
Syntax
smis namespaces
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Windows:
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis namespaces command and its abbreviated output:
smis namespaces interop root/ontap
