smis pools
The smis pools command lists the storage pools for storage systems.
Syntax
smis pools
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis pools command and its abbreviated output:
smis pools ONTAP_ConcretePool.InstanceID="ONTAP:0084259609:d46de7f0-3925-11df-8516-00a0980558ea" ONTAP_ConcretePool.InstanceID="ONTAP:0084259609:51927ab0-28b5-11df-92b2-00a0980558ea" ONTAP_DiskPrimordialPool.InstanceID="ONTAP:0084259609:Spare" ONTAP_DiskPrimordialPool.InstanceID="ONTAP:0084259609:Other" ONTAP_DiskPrimordialPool.InstanceID="ONTAP:0084259609:Present"
