smis refresh
By default, SMI-S Provider automatically gets information from storage systems every 60 minutes (3600 seconds). You can use the smis refresh command to manually refresh a particular storage system.
Syntax
smis refresh storage_system_ip
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
storage_system_ipRefreshes a specific storage system.
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis refresh command and its output:
smis refresh 10.32.1.4 Return Value= 0
