smis version
The smis version command displays the version of NetApp SMI-S Provider.
Syntax
smis version
[-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis version command and its output:
smis version ONTAP_SMIAgentSoftware.InstanceID="ONTAP5.2.2"
