smis volumes
The smis volumes command lists the traditional and flexible volumes for storage systems.
Syntax
smis volumes
[-t {http | https}]
For ONTAP, you must use the |
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis volumes command and its abbreviated output:
smis volumes ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="d46de7f0-3925- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="397cd140-3a45- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="69c472c0-4b27- 11df-8517-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="6c7ea0b0-3927- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609"
