Where to go next
You can find more information about Snap Creator, including release-specific information, on the NetApp Support Site.
Snap Creator Framework 4.3.3 Installation Guide
Describes how to install the Snap Creator Agent and Snap Creator Server. The Snap Creator Agent installation includes the IBM Domino plug-in.
Snap Creator Framework 4.3.3 Administration Guide
Describes how to administer the Snap Creator Framework after installation is complete.
Snap Creator Framework 4.3 Release Notes
Describes new features of, important cautions for, known problems with, and limitations of Snap Creator Framework 4.1.1.
SnapDrive 7.1 for Windows Installation Guide
Describes how to install SnapDrive for Windows.
ONTAP 9 Cluster Peering Express Guide
Describes how to quickly configure peer relationships between clusters and Storage Virtual Machines (SVMs).
ONTAP 9 Volume Disaster Recovery Preparation Express Guide
Describes how to prepare a storage system for SnapMirror replication.
ONTAP 9 Volume Disaster Recovery Express Guide
Describes how to prepare a storage system for SnapMirror recovery.
ONTAP 9 Volume Backup Using SnapVault Express Guide
Describes how to prepare a storage system for SnapVault replication.
NetApp Technical Report 3917: Best Practices for Domino on NetApp
Describes best practices for the IBM Domino plug-in.
Snap Creator Framework Discussions
Enables you to connect with peers, ask questions, exchange ideas, find resources, and share Snap Creator best practices.
Enables you to view videos that demonstrate key Snap Creator technologies.
