Viewing job status and logs in the Job Monitor
The Snap Creator Job Monitor is a dashboard-like interface for Snap Creator jobs. You can use the Job Monitor to view job status and download logs.
The Job Monitor indicates job status as follows:
indicates a job in progress. -
indicates a job that has completed successfully. -
indicates a job that completed with errors. -
indicates a job that failed.-
In the Profiles and Configurations pane, select the configuration file and click Management > Job Monitor at the top of the Snap Creator Framework window.
The Job Monitor pane is displayed, where you can view job status.
Select a job, then click Download Logs > Log_Type, where Log_Type is one of the following:
Out Logs provide verbose-level information for a job.
Debug Logs provides verbose-level information plus information useful in debugging.
GUI Logs provides information about Snap Creator GUI actions.The GUI log is not specific to the job that is selected.
In the download dialog, click Open or Save as required.
