SnapCenter Software 4.7
Types of restore strategies supported for automatically discovered SAP HANA databases
Contributors netapp-soumikd
You must define a strategy before you can successfully perform restore operations using SnapCenter. There are two types of restore strategies for automatically discovered SAP HANA databases.
Complete resource restore
  • Restores all volumes, qtrees, and LUNs of a resource
    • The Volume Revert option should be selected to restore the entire volume.
      Note If the resource contains volumes or qtrees, the Snapshot copies taken after the Snapshot copy selected for restore on such volumes or qtrees are deleted and cannot be recovered. Also, if any other resource is hosted on the same volumes or qtrees, then that resource is also deleted.
Tenant Database
  • Restores the tenant database
If Tenant Database option is selected, then HANA studio or HANA recovery scripts external to SnapCenter must be used to perform the recovery operation.
